bsnInitRcbSlot: slot 0 has venus radio(UNSUPPORT)
shawntls82
Hi All,
I'm trying to join an AIR AP-1220B-A-K9(converted to lightweight mode) to the WLC but it keeps looping on the JOIN and CFG state. Below are the output from console:
*Nov 16 17:13:56.792: %CAPWAP-5-SENDJOIN: sending Join Request to 10.253.201.48
*Nov 16 17:13:56.792: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov 16 17:13:57.360: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Nov 16 17:14:15.596: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.253.201.48:5246
*Nov 16 17:14:15.840: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 16 17:14:15.840: bsnInitRcbSlot: slot 0 has venus radio(UNSUPPORT)
*Nov 16 17:14:15.882: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Nov 16 17:14:16.977: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Nov 16 17:14:17.019: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
*Nov 16 17:14:17.065:  status of voice_diag_test from WLC is false
*Nov 16 17:14:17.065: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 16 17:14:17.092: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 16 17:14:18.093: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Nov 16 17:14:27.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.253.201.48 peer_port: 5246
*Nov 16 17:14:27.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov 16 17:14:28.797: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.253.201.48 peer_port: 5246
*Nov 16 17:14:28.798: %CAPWAP-5-SENDJOIN: sending Join Request to 10.253.201.48
*Nov 16 17:14:28.799: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov 16 17:14:29.361: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Nov 16 17:14:47.597: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.253.201.48:5246
*Nov 16 17:14:47.837: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 16 17:14:47.838: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Nov 16 17:14:47.838: bsnInitRcbSlot: slot 0 has venus radio(UNSUPPORT)
*Nov 16 17:14:47.956: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Nov 16 17:14:48.095: bsnUnlockDevice: not bring radio up: radio 0 is in admin disable state
*Nov 16 17:14:48.141:  status of voice_diag_test from WLC is false
*Nov 16 17:14:48.142: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 16 17:14:48.144: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Nov 16 17:14:48.165: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Nov 16 17:14:58.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.253.201.48 peer_port: 5246
*Nov 16 17:14:58.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Nov 16 17:14:59.789: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.253.201.48 peer_port: 5246
*Nov 16 17:14:59.790: %CAPWAP-5-SENDJOIN: sending Join Request to 10.253.201.48
*Nov 16 17:14:59.791: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Nov 16 17:15:01.273: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
Has anyone encounter this before, appreciate help and advise on this issue.
Thanks.
Shawn,
Excellent.. If you find this helpful please support the rating system by marking your question as answered. This will help others find a quicker resolve to their issues.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
5 Replies 5
George Stefanick
If your Ap has 802.11b radio it will not work. Requires 802.11g radio. Also what code is on your wlc ?
1200 won't work past 7.0 code ..
Hi George,
Thanks for your reply, I've checked the internal antenna card and it was this model AIR-MP20B 2.4Ghz, the 5Ghz antenna adapter is AIR-RM22a-AK9.
Does this means the internal 2.4Ghz radio card will not work with the controller?
I recall from way back that 802.11b radios arent supported. I also notice this from your cpature:
My hunch is that you need to upgrade that radio before she will join or remove that radio and see if that fixes the join process.
Hi George,
I think you are right, once I removed the internal radio AIR-MP20B, it joins to the WLC with the RM22A-A-K9 5Ghz antenna adapter.
I've also swapped the internal radio with AIR-MP21G-E-K9 and both radio joins to the WLC normally.
Therefore, I guess that the AIR-MP20B is not supported.
Shawn,
