c1130 telnet trouble
We have a problem with the access point 1130, with 12.3(8)JEA IOS. The problem is when we tried do telnet connection, the access point went down and it did not respond.
See the logs of the access point:
Process= "TPLUS", ipl= 0, pid= 65
-Traceback= 49E5C 14D1CC 1511A0 1A32B0 1AA31C 206AC4 20B620 3A6DE4 3A4278 3A56DC
3A5878 39E0C4 39DF40 39DEB8 146250
Feb 14 07:29:40.657: %SYS-2-MALLOCFAIL: Memory allocation of 1192 bytes failed f
rom 0x1A32AC, alignment 0
Pool: Processor Free: 327036 Cause: Memory fragmentation
Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "TPLUS", ipl= 0, pid= 65
Feb 14 07:30:10.646: %SYS-2-MALLOCFAIL: Memory allocation of 1192 bytes failed f
Pool: Processor Free: 327052 Cause: Memory fragmentation
Leo Laohoo
Have you tried using a different IOS version?
So you still have console connection? Can you make sure that your AP is configured for Telnet access? Feel free to post your config if that helps.
We were having some issues but they're all fixed now that we removed the TACAS lines.
Thanx
