Dear All,
We have more c819 routers to use LTE. A few of them works, few of them not. On the failed routers we dont get IP.
" CHAT3: Chat script lte finished, status = Connection timed out; remote host not responding"
chat-scrip is the same as well:
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
The only difference what I can see it is under "line 3".
Where lte works there is "rxspeed 100000000" and "txspeed 50000000" without "speed 9600".
line 3
rxspeed 100000000
txspeed 50000000
On the failed routers:
line 3
speed 9600
Can it be the problem? If I try to config any of these values on any routers, I have the following prompt:
"This command has no effect on this line; use modem AT commands instead"
I understand that these commands are relevant and saved to the modem, has to be confiugured with AT commands. BUT HOW?
Is it something to do with chat-script? or with modemcap? or with lte profile?
(this is the first time to meet with mobile net configuration, I am really not familiar with lte)
Thanks in advance.
Br, Levente
