C9115-AXI-E-EWC AP JOIN PROCESS ISSUE
henrielle
I just went back into networking, and I have a project where I should deploy 13 APs in a flat network (for the time being).
As far as I remember in WLC, the WLC holds the images wherein an AP joins, it will download the image from the controller itself.
In EWC I found out that it doesn't keep the image internally and the image location should be pointed in a TFTP server, etc.
Now I added a command in my EWC where to point the joining AP to get the image so it can successfully join to the EWC.
EWC:
wireless profile image-download default
 description "default image download profile"
 image-download-mode tftp
 tftp-image-path /
 tftp-image-server 192.168.0.132
As soon as I plug the AP I wanted to join, it gave me this cli output. (CLI output from the joining AP).
[*05/10/2025 14:45:52.3580] CAPWAP State: Join
[*05/10/2025 14:45:52.3770] shared_setenv PART_BOOTCNT 0 &> /dev/null
[*05/10/2025 14:45:52.9460] OOBImageDnld: OOB Image Download in ap_cap_bitmask(2)
[*05/10/2025 14:45:52.9460] Sending Join request to 192.168.0.174 through port 5258, packet size 1376
[*05/10/2025 14:45:57.6440] OOBImageDnld: OOB Image Download in ap_cap_bitmask(2)
[*05/10/2025 14:45:57.6450] Sending Join request to 192.168.0.174 through port 5258, packet size 1376
[*05/10/2025 14:45:57.6550] Join Response from 192.168.0.174, packet size 1397
[*05/10/2025 14:45:57.6560] AC accepted previous sent request with result code: 0
[*05/10/2025 14:45:58.2250] Received wlcType 2, timer 30
[*05/10/2025 14:45:58.2260] Primary-Replica: role 3, primary server '192.168.0.167', old 0
[*05/10/2025 14:45:58.2340] OOBImageDnld: Do common error handler for OOB image download..
[*05/10/2025 14:45:58.3110] status 'upgrade.sh: Script called with args:[CANCEL]'
[*05/10/2025 14:45:58.3580] do CANCEL, part2 is active part
[*05/10/2025 14:45:58.3790] status 'upgrade.sh: Cleanup tmp files ...'
[*05/10/2025 14:45:58.4030] Primary-Replica: Set to Replica, retry 44, set_tftp_server 0, Primary server 192.168.0.167, Join role Replica, tftp_timeoutCnt 3
[*05/10/2025 14:45:58.4090] Image pre-download request for version 17.15.3.28.
[*05/10/2025 14:45:58.4090] Request to close the file..
[*05/10/2025 14:45:58.4090] wtpOpenImgFile: image file closed, dcb->fd set to -1.
[*05/10/2025 14:45:58.4480] status 'upgrade.sh: Script called with args:[PRECHECK]'
[*05/10/2025 14:45:58.4930] do PRECHECK, part2 is active part
[*05/10/2025 14:45:58.5050] status 'upgrade.sh: Cleanup tmp files ...'
[*05/10/2025 14:45:58.5520] status 'upgrade.sh: /tmp space: OK available 96444, required 50000 '
[*05/10/2025 14:45:58.5530] Memory check success. Memory: (210 required, 1403 current)
[*05/10/2025 14:45:58.5530] Launching image pre-Download task, prev_taskId 0
[*05/10/2025 14:45:58.5530] Launching image pre-Download task success and id(1598524976)
[*05/10/2025 14:45:58.5530] Starting image pre-download task, role=1
[*05/10/2025 14:45:58.5530] Replica Predownload(5): Primary server 192.168.0.167, ver 0.0.0.0, retry 44, timeout 3, image str /tftpboot/ap1g7-pre17.15.3.28.tar
[*05/10/2025 14:45:58.5540] Save Predownload URI tftp://192.168.0.167//tftpboot/ap1g7-pre17.15.3.28.tar
[*05/10/2025 14:45:58.5960] status 'upgrade.sh: Script called with args:[-r 44 -s tftp://192.168.0.167//tftpboot/ap1g7-pre17.15.3.28.tar -n /tftpboot/ap1g7-pre17.15.3.28.tar FLEX_REPLICA_DOWNLOAD]'
[*05/10/2025 14:45:58.6330]
[*05/10/2025 14:45:58.6330] CAPWAP State: Image Data
[*05/10/2025 14:45:58.6390] AP image version 17.9.4.27 backup 17.9.4.27, Controller 17.15.3.28
[*05/10/2025 14:45:58.6390] Version does not match.
Now I am confused why is it pointing to the 192.168.0.167, when I manually configured in the EWC that the tftp is 192.168.0.132 (which is my PC).
Somehow after a while the joining AP suddenly joined the EWC process, and I cannot comprehend what happened exactly.
The 2nd AP became Standby as well.
If anyone can explain I will be very happy.
Thanks in advance.
Rich R
Are your APs all the same model? If so then it is possible for them to download the image from the EWC - still best to have TFTP setup/configured though.
You might have another AP also running as EWC controller?
Check your controller config - you might have multiple tags and profiles configured with the other config?
Check the AP is getting the tags and profiles you're expecting - show ap tag summ.
The AP might have that config configured before it even joins (from previous setup) - have you done a factory default reset of the AP?
Hi!
Yes, all APs are C9115AXI-E and yes, I reset the AP that I made as controller due to some software upgrade mistake.
The rest of the APs are untouched (12 qty). 1 I used for testing, and it is weird since it joined the controller after some time.
There are no profiles other than the default.
That config has to come from somewhere!
Either another EWC controller or saved on that AP.
Use a packet capture to see what the AP is talking to?
