C9800 Wireless configure combined Local MAB and 802.1X
Hi  Experts.
Whether the C9800 supports the SSID configuration that combines 802.1X and local MAB authentication ?
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
marce1000
        - FYIhttps://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m_multiple_authc_for_a_client.html
 M.
I also found the document you provided, I can't understand whether the MAB mentioned in MAB+802.1X is the MAB on the RADIUS SERVER side, because I can do MAB+PSK normally (both locally on the C9800), while MAB+802.1X (MAB is local to C9800, and 802.1X is RADIUS Server authentication); the authorization list of MAB+PSK authentication mode and MAB+802.1X authentication mode are the same.
