03-23-2015 12:13 PM - edited 07-05-2021 02:46 AM
Hi all,
I have 2 lightweight APs (AIR-CAP1602I-E-K9) connected to a wireless lan controller 2500. I am trying to enable radio measurements, however after configuring the WLC, RM status is still reported as disabled. I used this document http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_010000111.html#ID2037 to configure the WLC.
Here is my current config:
1. CCX-Lite is enabled
> show run-config
CCX-lite status ............................ Enabled
2. AeronetIESupport for the wlan of interest is enabled
> show wlan 14
CCX - AironetIe Support.......................... Enabled
3. RM is enabled globally
> show advanced 802.11a ccx global
802.11a Client Beacon Measurements:
enabled with (interval=60) seconds
4. RM is enabled for the AP
> show advanced 802.11a ccx ap AP_1
802.11a Client Beacon Measurements for Cisco AP:
However, when requesting the RM status on the controller, every type of measurement is shown as disabled:
> show ap ccx rm AP_1 status
B Radio
Beacon Request................................. Disabled
Channel Load Request........................... Disabled
Frame Request.................................. Disabled
Noise Histogram Request........................ Disabled
Path Loss Request.............................. Disabled
Interval....................................... 60
Iteration...................................... 0
A Radio
When checking the client RM status, I get the following results:
> show client ccx rm Client_MAC status
Client not in the unicast rm list
> show client ccx rm Client_MAC report beacon
Client not configured for ccx rm
> show client detail Client_MAC
Client CCX version............................... 6
CCX Foundation Service version................... 1
CCX Management Service version................... Not Available
CCX Voice Service version........................ Not Available
CCX Location Service version..................... Not Available
My questions are:
1. Is there an extra config on the WLC to enable Radio Measurements?
2. Why is the client reported as having RM disabled?
3. Are there any additional client configurations that must be done?
Thank you.
12-06-2016 03:19 PM
Hi:
What do you see after issuing the following CLI commands (wait 5-10 secs after last command):
test ccx rm unicast <STA MAC in xxxx.xxxx.xxxx format> beacon disable
test ccx rm unicast <STA MAC in xxxx.xxxx.xxxx format> send 5 1
debug disable-all
debug ccxrm all enable
test ccx rm unicast <STA MAC in xxxx.xxxx.xxxx format> beacon enable
Dennis
dB Performance Inc.
