10-04-2017 05:20 AM - edited 07-05-2021 07:43 AM
We have a 4404 controller running on 7.0.116.0. All the ap's registered to that wlc suddenly had capwap flapping. Aps were then stable after few mins. We didnt see any issue on the switch/fw (L3 interface created). Any idea what could be checked ?
10-04-2017 05:37 AM
it could be a network replated issue.
1. what does the swicth interface look like ? How is it configured and are there any errors on AP connected ports ?
2. What are the AP logs showing? Also, on the controller web interface under Monitor > Statistics > AP Join, what do you see under Last Error Summary?
Dont forget to rate helpful posts
10-04-2017 05:46 AM
Checked network related logs.. no fault found. Please find the below error from AP join statistics.
Last AP Connection Failure | |
Last AP Disconnect Reason | |
Last Error Occurred | |
Last Error Occurred Reason | |
Last Join Error Timestamp |
10-04-2017 05:50 AM
must be a bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCum86401/?referring_site=bugquickviewredir
10-04-2017 05:57 AM - edited 10-04-2017 05:59 AM
Chekc if LWAPP and CAPWAP ports are open to buid a tunnel from AP to wlc.
LWAPP port 12222 and 12223
CAPWAP: 5246 - control, 5247 - data
Example:
When an AP running a version before 5.2 joins a 5.2. WLC, the following process is used:
AP joins the 5.2 controller using LWAPP 12223.
AP downloads 5.2 code and reboots.
AP joins the 5.2 controller using CAPWAP 5246.
If the AP is unsuccessful, it falls back to LWAPP. *note that a CAPWAP AP will be not be allowed to register using LWAPP to a CAPWAP WLC*
11-08-2023 03:54 AM
Hello, i know this is a old post, but; there is a way to check from wlc cli the operation of tunnel capwap of an AP, for example i have a branch with 2 APs and want to know if the tunnel capwap data and control are ok by a cli command or something, i know that on gui on specific ap i can check the ap associated time and gives me a reference about the control tunnel, but wanna check the data tunnel, thanks a lot.
