06-21-2016 11:37 AM - edited 07-05-2021 05:16 AM
I have two sites
Site A: Cat 3850 as MC with one 3702I AP connected
Site B: Cat 3850 as a MA with three 3702I AP connected
Site A is setup and working well. Site B vlans work fine when connected to a port on the switch. I can not cannot get the MA to connect to the MC nor will the AP's connected to the MA.
I have set the MA with the MC's ip and manually set the ip's on the AP's. Still not connecting. Any help would be appreciated.
06-21-2016 01:28 PM
Hi Walter,
Have you configured mobility peering between MA & MC. Refer below post (you can think of 5760 as 3850MC in your case)
https://mrncciew.com/2013/12/14/3850ma-with-5760mc/
Rasika
*** Pls rate all useful responses ***
06-22-2016 04:07 AM
Ok so that worked. Are the wlans from the MC supposed to copy down to the MA? The AP's connected to the MA do not show registered in the controller just the MA.
06-22-2016 12:39 PM
There is a new feature added in 16.2.1 code to do this. Refer below
I would suggest manually copy wlan config from MC to MA unless you tested this new feature in your environment.
"show wireless mobility ap-list" on your 3850MC should show the AP registered in MA as well.
Rasika
