Catalyst 9800 CL and AP1562 mesh network - failing to create mesh
christophekey
Mesh AP failing to join Root AP.
Clean setup of the Catalysy 9800 CL WLC.
Add AP1562 to WLC, set up as Root AP.
Add AP1562 to WLC, set up as Mesh AP.
Root AP connects back to WLC via IE4000
Mesh AP connected to IE1000
Profiles, tags VLANS all good.
Go back through and double check config and clock that on the Mesh tab for the AP config, alert given for Ethernet bridging (which i require). Checking the mesh profile, Eth bridging is enabled, however the warning would suggest otherwise.
Any suggestions or guidance on where I am going wrong please?
I can’t join Ap1562E with wlc 9800.Please help me .
Have you added the mac address to the 9800? Take a look at this video as it might help:
https://www.youtube.com/watch?v=HwF5SJRL8R4
-Scott
Scott Fella
There are various warnings which to me is more informational. Look at it as a reminder not that you are missing a setting.
-Scott
