12-14-2010 10:38 AM - edited 07-03-2021 07:32 PM
Can you export a certificate from your Active Dr/Domain controller and import it as a certificate authority in a Cisco Secure ACS appliance? Then assign authentication protocals to it? If so, what is the process to make this work?
Thanks, Tandrist
Solved! Go to Solution.
12-15-2010 08:22 AM
Yes, you can install certificates on the ACS under the Certification Authorities as CA certificates and use them for EAP-TLS for example, making the ACS to trust these CAs for clients using certs issued by the CAs.
HTH,
Tiago
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
12-15-2010 08:22 AM
HTH,
Tiago
