Cico Aironet 350 Series Adapter and Netgear WGT624 Wireless router
randala
Can anyone help me in configuring the Cisco Aironet 350 adapter to talk to the Netgear WGT624 wireless router? I've been at it for a couple of hours now and can not nail it down. Thanks
Yes, I have the client software installed as this is the same card that I use at work so I'm sure the card works. I'm just not sure I have it configured correctly for the Netgear router. Do I have to do anything to the router in order for it to recognize the Cisco adapter or should it pick it up automatically?
amitubale
connect tot he router interface( probably http://192.168.0.1 or http://192.168.2.1 ) and check the SSID.
Then add a profile in the cisco ACU ( for non Windows XP machines) and put the SSID. This should take car of the problem.
