Cisco 1130AG Autonomous DHCP problems
dustin.sondenaa
I am having a problem getting DHCP to work for interface BVI1. I have tried everything I can think of and now am asking for the smarter peoples help. DHCP works great for the clients but BVI1 will not get a DHCP address no matter what I try. Below is a copy of the config for the AP and the port.
AP
Current configuration : 2754 bytes
version 12.4
no service pad
service password-encryption
hostname Library-103
logging rate-limit console 9
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip dhcp-server 155.31.18.69
dot11 syslog
dot11 vlan-name Wireless vlan 3402
dot11 ssid Eaglenet_CiscoTest
   vlan 3402
   authentication open
   guest-mode
   mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
station-role root access-point
interface Dot11Radio0.9
encapsulation dot1Q 9 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.3402
encapsulation dot1Q 3402
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
interface Dot11Radio1.9
no ip route-cache
bridge-group 1
interface Dot11Radio1.3402
no ip route-cache
bridge-group 254
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.9
no ip route-cache
bridge-group 1
interface FastEthernet0.3402
no ip route-cache
bridge-group 254
interface BVI1
ip address dhcp
no ip route-cache
ip default-gateway 155.31.9.254
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community Cisco_Wireless RO
bridge 1 route ip
line con 0
line vty 0 4
end
Switch
interface GigabitEthernet1/0/47
description Meraki WAP
switchport access vlan 9
switchport trunk native vlan 9
switchport trunk allowed vlan 7,9,29,3402
switchport mode trunk
switchport nonegotiate
priority-queue out
mls qos trust dscp
15 Replies 15
Sorry I guess I was reading too fast and missed that. You were both correct that command was the problem and once I removed it I got DHCP. Thank you very much!
Sorry I had to give the correct answer to Stephen becuase he did mention it first
