10-29-2012 03:53 AM - edited 07-03-2021 10:56 PM
i would like to ask if a cisco aironet 1162 access point can work without those antennas as well as an access controller.
thanks in advance
11-18-2012 03:41 AM
Do you mean 1262?
They are able to work on a WLC and like I know you can order 1260series with internal antennas, but not sure..
11-18-2012 08:25 AM
So I guess we have to determine is your talking about a 1262 or maybe a 1142. 1262 only come in with external antennas, the 1142 only come in with internal antennas. Both can be used with or without a WLC but requires you to tftp the autonomous code to the ap. This can happen either way. You can convert autonomous to LWAPP by tftp also.
11-18-2012 02:14 PM
Agree with Scott.
If you don't want to use antennas then a 1040 or 1140 is what you should be looking for.
If you want something more affordable than the 1040 and 1140, which by the way are 802.11 a/b/g/n, then you may want to look at the old 1130 (802.11 a/b/g only).
