Post upgrade of our controllers to 6.0.199 two our our CiscoAP1231's didnt come back up and if we console into them it seems to be a flash error.
The device will no longer allow access to flash (DIR fails) and can't get the updated image.
I've tried the factory reset but it still has the same error.
Is there anyway to re-format the flash or is this likely to be a hardware failure?
thanks,
matt
