03-12-2017 07:38 PM - edited 07-05-2021 06:41 AM
Hi fellow experts,
The customer is looking for solution for AP 1240AG to be powered on by 802.3af non-Cisco switch. What configuration required to make it works?
I have tried to google it, but there is no result about it.
Thanks.
03-12-2017 10:18 PM
There are so many methods of powering them up. Power cube, injector and mid-span switches.
Depends on the budget and the need.
The 1240 is already EoS/EoL. There are many power cubes and injectors currently available in various markets.
03-12-2017 10:21 PM
Thank you. But the customer is looking for the solution to use their current old AP and non-Cisco PoE switch, without purchasing anything.
03-12-2017 10:30 PM
By default, the AP should work with any PoE switch that can provide 15.4w of power.
