Cisco 1242 Antenna Remote Management Question
lkqciscotech
Is there a command that will let me know if the antennas of a 1242 are connected to the 2.4GHz side or the 5GHz side?
Stephen Rodriguez
There is no command that will give you that information, per se.  In general the AP does not "know" about the antenna as they are not part of the config, and are completely external
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
