Cisco 1410 bridge issue
Yde Ihop
Hello All,
After resetting a 1410 wireless bridge to its factory settings, the following errors messages appeared in its log buffer :
*Mar  1 00:00:14.314: %DOT11-3-RF_LOOPBACK_FREQ_FAILURE: Radio failed to pass RF
loopback test at freq 5745Mhz
*Mar  1 00:00:14.336: %DOT11-3-RF_LOOPBACK_FREQ_FAILURE: Radio failed to pass RF
loopback test at freq 5765Mhz
*Mar  1 00:00:14.359: %DOT11-3-RF_LOOPBACK_FREQ_FAILURE: Radio failed to pass RF
loopback test at freq 5785Mhz
*Mar  1 00:00:14.381: %DOT11-3-RF_LOOPBACK_FREQ_FAILURE: Radio failed to pass RF
loopback test at freq 5805Mhz
*Mar  1 00:00:15.390: %DOT11-3-RF_LOOPBACK_FAILURE: Interface Dot11Radio0 Radio
failed to pass RF loopback test
The IOS version is  12.4(21a)JY. i am attaching a copy of the show tech-support command.
How can I fix this issue ?
Thank you,
George Stefanick
Can you attach the show run ?
Hello George,
The running configuration is as follows:
sh run
Building configuration...
Current configuration : 1033 bytes
version 12.4
no service pad
service password-encryption
hostname bridge
no logging console
enable secret 5 $1$lzOf$4Jo7ybLQ1AjdzOgNBTwfR.
no aaa new-model
ip domain name yaoundeihop.net
dot11 syslog
dot11 ssid autoinstall
   authentication open
   guest-mode
--More--                              infrastructure-ssid
username Cisco password 7 00271A150754
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid autoinstall
station-role install automatic
rts threshold 4000
concatenation
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
--More--                           interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 172.18.1.150 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Thank you,
