Cisco 1812w with wpa2
rdp1960
Buongiorno.
Ho un Cisco 1812w con un'interfaccia ISDN che devo smaltire.
Non voglio buttarlo via.
Voglio usarlo come access point.
Ma non ha la crittografia wpa2.
c'è una versione del firmware per questo?
Grazie
2 Accepted Solutions
Yes, 12.4.
 You don't need to buy as long as you have access to Cisco download page and be able to download content(require privilege, usually contract)
 However, this device is end of life,so, you need to upgrade and take all the risk on your own.
-If I helped you somehow, please, rate it as useful.-
 which IOS do you have?  The latest version is 15.1.4M12a.  This version must support.
Thanks for the reply.
I'm not an expert but if I understand well on the router is version 12.4 installed. Can the version you suggest be purchased?
Thank you
Here is the output of the show version command
show version
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(15)T5, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 30-Apr-08 12:09 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH12, RELEASE SOFTWARE (fc1)
Router uptime is 15 minutes
System image file is "flash:c181x-advipservicesk9-mz.124-15.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1812W (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FCZ122012QA, with hardware revision 0000
10 FastEthernet interfaces
1 ISDN Basic Rate interface
2 802.11 Radios
31808K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2142
r
Yes, 12.4.
Grazie.
