j_friedrich
Beginner
Cisco 1941W built-in AP goes down?
Hi guys,
     Any ideas on how to debug why sometimes the dot11radio0 / 1 go down?  Sometimes, the lights on the router indicating the radio status go out.  Usually, a reload of the ap will bring them back up...
Maybe hardware is starting to fail?  Just unsure on how to debug to find out why it turns off sometimes.
Thanks for everyone's help.
Jason
1 REPLY 1
Scott Fella
Hall of Fame Guru
Might be that your hardware is failing... I have the same model for my home lab and I don't have that issue:)  Take a look at the logs on the router and see if you see anything that shows the ap failing or shutting down for some reason.  I would open a TAC case though and get it replaced.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Content for Community-Ad
