Cisco 1941W - with external antenna cable
EvaldasOu
Level 4
Level 4
Hello guys!
I would like to ask, maybe you know or maybe you have tried to use these cables from Cisco :
Feature AIR-CAB020LL-R AIR-CAB050LL-R AIR-CAB100ULL-R AIR-CAB150ULL-R
Cable Length 20 ft (6 m)50 ft (15 m)100 ft (30 m)150 ft (46 m)
Transmission Loss 1.3 dB3.4 dB4.4 dB6.6 dB
for Cisco 1941W router with external antennas?
Scott Fella
How far are you trying to extend the antennas? Those will work to reduce the attenuation if trying to extend the placement of the antennas. Basically they are LMR cables.
-Scott
Scott Fella
-Scott
EvaldasOu
Level 4
Level 4
Hi Scott!
Just few meters. To get wireless outside of the server room.
Sent from Cisco Technical Support Android App
Yes those a cable will work.
-Scott
