Cisco 2504 controller, setting management wlan interface Vlan Identifier to anything but 0 loses management ability
slwdaw_2
Community Member
I have setting the Management Interface Vlan Identifier to 0 or untagged.
If i change this to a vlan, I am unable to manage the device, is this correct?
Steve
Surendra BG
If u make it untagged then specify the NATIVE vlan on the switchport..
If u tag the management interface, then dont configure the native vlan on the switchport..
Both the cases u will be able to access!!
Lemme know if this answered ur question!!
Surendra
Surendra BG
Surendra BG
Surendra
Surendra BG
George Stefanick
I will piggy back on Surendra's comment. Its best to TAG your interface. If you plan to do QoS you can trust CoS on the link and not have to worrk about the mangment traffic not being trusted w.o having to do a policy map.
Pointed to be noted George!
Surendra BG
