Cisco 3650 Converged LAN/WLAN Design: Radius Authentication configuration example needed
derobbacher
Hello Cisco-Experts,
one of our customers would like to deploy Cisco3650-switches with integrated WLC-functionality.
The platform is new to me and I have started to configure some basic settings.
Unfortunately I cannot find information on how to implement 802.1x Radius authentication.
Do You know, where I can find detail information or an example how to implement this ?
Thank You
Wini
Rasika Nayanajith
Hi Wini,
See if this helps
http://mrncciew.com/2013/12/06/wlan-config-with-3850-part-2/
Rasika
*** Pls rate all useful responses ****
Rasika Nayanajith
Hi Wini,
See if this helps
Rasika
derobbacher
Hello Rasika,
thank You very much for link to Your 802.1x authentication configuration
on similar 3850 platform.
Very useful stuff.
Is it possible to setup the Radius -Server function on the switch itself ?
I'm asking because I would like to test the setup in our office before rollout to customer.
Kind regards
Wini
