cisco 3850 not register APs
Hello.
I have 3 3850 switches. One is used as MC, two are used as MA. With one of it I succesfully created tunnel, but the second one do not allow me to register points and do not start tunnel. Also on MC I get message:
*May 14 2014 06:47:11 EET: *%MM-3-CONFIGDOWNLOAD_FAILED: STANDBY:2 wcm:  Failed to send a config download response packet sending packet to 10.2.53.104.   (sw_wlc_stack-2)
*May 14 2014 06:47:11 EET: *%MM-6-PING_RECEIVER_ENTRY_DELETED: STANDBY:2 wcm:  Deleted ping receiver entry(10.2.53.104) from hearbeat list for WLAN(-1).   (sw_wlc_stack-2)
*May 14 2014 06:47:14 EET: *%MM-3-CONFIGDOWNLOAD_FAILED: 1 wcm:  Failed to send a config download response packet sending packet to 10.2.53.104.
On this MA:
sw_mc_11#sh wireless mobility summary
Mobility Agent Summary:
Mobility Role                                   : Mobility Agent
Mobility Protocol Port                          : 16666
Mobility Switch Peer Group Name                 :
Multicast IP Address                            : 0.0.0.0
DTLS Mode                                       : Enabled
Mobility Domain ID for 802.11r                  : 0xac34
Mobility Keepalive Interval                     : 10
Mobility Keepalive Count                        : 3
Mobility Control Message DSCP Value             : 0
Switch Peer Group Members Configured            : 0
Link Status is Control Link Status : Data Link Status
The status of Mobility Controller:
IP              Public IP            Link Status
10.1.5.30       10.1.5.30            DOWN : DOWN
sw_mc_11#
Config on two MA are similar but only one works:
sw__serverna_mc_01#sh wireless mobility summary
Mobility Switch Peer Group Name                 : PortCity
DTLS Mode                                       : Enabled
Mobility Control Message DSCP Value             : 48
Switch Peer Group Members Configured            : 2
10.1.5.30       10.1.5.30            UP   : UP
Switch Peer Group members:
IP              Public IP            Data Link Status
10.2.53.100     10.2.53.100          UP
10.2.53.104     10.2.53.104          DOWN
sw__serverna_mc_01#
Could someone help me? And not-working MA does not register APs(((
ITNettverk HiBu
Hello.
I have the same problem.
Did you find a solution?
Can you explain your set up & post "show wireless mobility summary" output from your MC & MAs
Rasika
**** Pls rate all useful responses ****
