Cisco 4331 4G LTE NIM AT&T and Verizon Configuration Problem
Antonio Mercado
Howdy,
Just purchased 10 x Cisco 4331 router with dual 4G LTE AT&T and Verizon NIM modules, and have modeled the configuration off other Cisco routers (2901 with first gen NIM modules) that have air cards installed.  I am having a pretty tough time getting the air cards to acquire an IP address. They are registered with both carriers and are pulling LTE service and a cellular number.  The new 4K router cellular config will not let me enter "dialer string lte".  I have put all the configuration I can think of to help with the resolution.
The configuration of the AT&T aircard is
controller Cellular 0/1/0
lte modem link-recovery rssi onset-threshold -110
lte modem link-recovery monitor-timer 20
lte modem link-recovery wait-timer 10
lte modem link-recovery debounce-count 6
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
track 10 ip sla 10 reachability
delay down 15 up 10
track 11 ip sla 11 reachability
delay down 15 up 10
track 20 ip sla 20 reachability
delay down 15 up 10
track 21 ip sla 21 reachability
delay down 15 up 10
interface Cellular0/1/0
description AT&T
ip address negotiated
zone-member security OUTSIDE
dialer in-band
dialer idle-timeout 0
dialer enable-timeout 1
dialer watch-group 1
dialer-group 1
ip sla 10
icmp-echo XX.XX.XX.XX source-interface Cellular0/1/0
threshold 40
timeout 1000
frequency 3
ip sla schedule 10 life forever start-time now
ip sla 11
threshold 40
timeout 1000
frequency 3
ip sla schedule 11 life forever start-time now
ip sla 20
icmp-echo XX.XX.XX.XX source-interface Cellular0/2/0
threshold 40
timeout 1000
frequency 3
ip sla schedule 20 life forever start-time now
ip sla 21
threshold 40
timeout 1000
frequency 3
ip sla schedule 21 life forever start-time now
dialer-list 1 protocol ip permit
IT-4331-KIT1-RTR#show cellular 0/1/0 all
Hardware Information
Modem Firmware Version = SWI9X15C_05.05.58.00
Modem Firmware built = 2015/03/04 21:30:23
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = XXXXXXXXXXXX
International Mobile Equipment Identity (IMEI) = XXXXXXXXXXXX
Integrated Circuit Card ID (ICCID) = XXXXXXXXXXXXXXXX
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) = 1XXX4490216
Current Modem Temperature = 27 deg C
PRI SKU ID = 9903214, PRI version = 05.09
Profile Information
Profile 1 = INACTIVE* **
PDP Type = IPv4
Access Point Name (APN) = Broadband
Authentication = None
Profile 2 = INACTIVE
* - Default profile
** - LTE attach profile
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current System Time = Tue Apr 11 15:27:20 2017
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = AT&T
Mobile Country Code (MCC) = 310
Mobile Network Code (MNC) = 410
Packet switch domain(PS) state = Attached
Registration state(EMM) = Registered
EMM Sub State = Normal Service
Tracking Area Code (TAC) = 29456
Cell ID = 138394889
Radio Information
Radio power mode = ON
LTE Rx Channel Number = 1125
LTE Tx Channel Number = 19125
LTE Band = 2
LTE Bandwidth = 15 MHz
Current RSSI = -82 dBm
Current RSRP = -114 dBm
Current RSRQ = -13 dB
Current SNR = 0.6 dB
Radio Access Technology(RAT) Preference = GWL
Radio Access Technology(RAT) Selected = LTE
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS State: GPS disabled
SMS Information
Incoming Message Information
SMS stored in modem = 1
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 1
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status = 0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
Reference Number = 0
Result Code = 0x0
Diag Code = 0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on 4G modems.
Modem Crashdump Information
Modem crashdump logging: off
Been working on this for close to a month. Any help on this would be greatly appreciated!
Thanks!
0 Replies 0
