10-07-2014 01:32 PM - edited 07-05-2021 01:40 AM
Can anyone tell me if there are any issues with using Cisco 1242 access points along with a 4400 series wireless controller. Does either device need a specific firmware?
Chris
Solved! Go to Solution.
10-07-2014 01:57 PM
No issues, it will work.
If possible get your 4400 upgraded to 7.0.x code as it is the last supported code for 4400. APs will automatically get image from WLC once register
Refer this table for any compatibility information
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rasika
**** Pls rate all useful responses ****
10-07-2014 01:57 PM
Rasika
10-07-2014 02:03 PM
Thanks for the help
Chris
10-07-2014 02:04 PM
Hi Chris,
Pls mark the thread as answered if you get the info you looking for
Rasika
