ā03-09-2012 09:15 AM - edited ā07-03-2021 09:45 PM
I have a cisco 4402 wireless lan controler, I have a campbell scientific CR3000 device with and ethernet module. When I add the device with an ethernet cable directly to the network I can see the static IP for the device and can ping it. But when i add the trendnet 450 wireless N gaming Adapter TEW-687GA I cant ping the device anymore. I gave the adapter a static ip 10.0.2.210 and the CR3000 is 10.0.2.211. I can see the admin page for the adapter bridge on the network and can ping it. So is there a setting on the 4402 wireless controller that I am missing?
ā03-09-2012 09:18 AM
It sounds like you may be getting stopped because of the MAC binding table.
config network ip-mac-binidng disable
and see if you are able to use the wireless on the device.
Steve
ā03-09-2012 10:13 AM
Its not letting me do the command in the CLI
i am running software version 5.0.148.0
ā03-09-2012 01:06 PM
this is all i see
(Cisco Controller) >show network summary
RF-Network Name............................. CSRL-WRLS
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Shell (ssh).......................... Enable
Telnet...................................... Enable
Ethernet Multicast Mode..................... Enable Mode: Ucast
Ethernet Broadcast Mode..................... Enable
IGMP snooping............................... Enabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
ARP Unicast Mode............................ Disabled
Cisco AP Default Master..................... Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Disable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Over The Air Provisioning of AP's........... Disable
Apple Talk ................................. Enable
AP Fallback ................................ Disable
--More-- or (q)uit
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
802.3 Bridging ............................. Enable
ā03-09-2012 01:23 PM
Whatever you do, stay AWAY from firmware version 5.X.
Upgrade to 7.0.230.0 instead.
ā03-10-2012 05:33 AM
First I would upgrade like Leo mentioned. Then in your SSID advanced tab, make sure passive client is enabled.
ā03-11-2012 09:49 AM
Unrelated to your issue but I want to mention... Trendnets arent the most robust client adpaters. I hope you dont have issues with these romaing ... I had about 40 and replaced them with Cisco 1131 in bridge mode.
