Jeff Berg
Beginner
Cisco 5508 Hreap - slow wireless throughput
I have a Cisco 5508 setup at a host site with 3 other sites connected using hreap on 1252APs. When doing testing of network speed I find that the throughput from the wireless to wired network is at about 18mbps yet the same test  on wired side is 85-100mbps and wireless to wireless is 18mbps
Any ideas what could cause this
4 REPLIES 4
Hi Jeff,
do you use local switching in hreap mode?
If you are tunneling traffic back to WLC WAN connection could be your limiting factor.
Sebastian
It is set to local swiching for each of the five vlans setup- a tracert shows correct path from point a to b
Hm, just guessing is hard. So ...
Can you upload the configuration?
Which standard do you use? .11n? Encryption method?
Where you the only one on ap while taking the tests?
Have you tried some tests at various daytimes?
Any chances to check for interference or change channels?
Sebastian
as well, what type of switchport is the AP connected to?  10/100 or 10/100/1000
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Create
Recognize Your Peers
Content for Community-Ad
