Cisco 5508 WLC upgrade path from 6.0.196.0 to 8.5.161.0
networklearner1
Hello All,
I have setup a new WLC (Cisco-5508) and the existing IOS version in pretty old (6.0.196.0)
Could anyone please confirm if I can directly upgrade it to 8.5.161.0 or is there any specific upgrade path that needs to be followed.
2 Accepted Solutions
Leo Laohoo
Upgrade to 8.5.X.X is fine.
marce1000
 - That is pretty ancient indeed , as per https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html
  >...The 8.5 Mainline branch supports 5508/8510/5520/8540/3504/2504/7510/WiSM2/vWLC controllers.  It supports intercontroller mobility (IRCM) between AireOS and old "New Mobility" ("Converged Access") controllers (5760/3850/3650.)  It does not support IRCM with 9800 controllers.  For 8.5 Mainline deployments, TAC recommends 8.5.182.7 or 8.5.182.11.
  - The idea being that the aireos platforms are getting older and it becomes more and more advised to use the last release that they can (still) run ,
 M.
5 Replies 5
Leo Laohoo
Thank you
marce1000
 M.
Scott Fella
Make sure you run a diff between your existing configuration and the configuration after you have upgraded.  That way you are aware of any changes to the configuration that can cause issues.  Also, make sure your ap's are supported on the newer code as the v6.x is very old.
-Scott
Rich R
As Marce has already highlighted you should not be upgrading to 8.5.161.0 - you should be using 8.5.182.11 (link below).
