03-26-2015 09:40 AM - edited 07-05-2021 02:48 AM
Does anyone know, if the Cisco 7925G phone is supported by the 2702I/E access points? The Deployment Guides don't seem to be actual , because I can't find a documentation for it.
Tanks in advance and Best Regards!
03-26-2015 12:52 PM
Yes, Cisco 7925G will support on any Cisco enterprise wireless deployment & not depend on AP hardware model
Rasika
**** Pls rate all useful responses ****
06-01-2015 10:20 AM
7925G is supported on any kind of wireless network on enterprise and SOHO setup.So no need to worry about AP model.
09-02-2015 04:26 AM
Which Cisco access points are supported with the Cisco Unified Wireless IP Phone 7925G?
