Cisco 9800 WLC Cisco C9800-L-F-K9 Chassis] locally hosted Custom Webauth Page.
Hi friend,
We have a Cisco 9800 WLC. [Cisco C9800-L-F-K9 Chassis].
We would have locally hosted guest auth page. But we would customize pages with logos etc. At the moment itis showing default cisco logo.
I tried but could not find a guide or help to do it on Cisco 9800 wlc. Also when checked no custom web auth bundel available for Cisco C9800-L-F-K9 Chassis.
Any body here can help or guide to do it.
Dilip
balaji.bandi
I tried some time back in Lab. good blog  here :
check bottom of the blog - nice how to customise the portal.
https://wifininjas.net/2019/10/24/wn-blog-017-cisco-c9800-local-web-auth-config/
BB
Hi There, I am running 17.3.4, any difference in you post.  Also, you do have to have an actual internet connection for it to work?  Or can i just connect to the wifi.
Problem i am having is a client will connect to the Wap, authenticate.  Wifi shows open secured, no internet as it is not connected.  But i never see a login page.  Everything is setup for local to the controller.
Grendizer
I just published a document that has step by step instructions on how you can do that https://community.cisco.com/t5/wireless-mobility-documents/ewlc-9800-local-webauth-with-custom-pages-using-the-webauth/ta-p/4165243
I am looking at your document, and i do not see where you are authenticating from the WLC first with this part of the document:
Sample config for ISE or any RADIUS Server:
radius server ISE
address ipv4 x.x.x.x auth-port 1812 acct-port 1813
timeout 5
retransmit 3
automate-tester username dummy probe-on
key XXXXXXXXXXX
exit
aaa group server radius RADIUS-GROUP
server name ISE
exit
aaa authentication dot1x ISE-Method group RADIUS-GROUP
aaa authorization network ISE-Method group RADIUS-GROUP
aaa accounting identity default start-stop group RADIUS-GROUP
aaa authentication webauth default local group RADIUS-GROUP
end
Note: as you can see in the last cli command, I’m checking local users first then ISE.
I am trying to only use the WLC for all authenticationg
