cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
CISCO ACCESS POINTS AIR-CAP3702I-H-K9
Hi gents, ladys
I am working offshore and in our vessel we have several Access points AIR-CAP3702I-H-K9 installed in the corridors of all vessel, but inside the cabins the signal is too weak even went the access point is in front of the cabin(5 meters) if the door of the cabin is open the signal is OK, but when the door is closed the signal is weak, somebody can support me?, what we can do to solve this?, it is just configuration of the access point or is necessary install repeaters or another devices to increase the coverage of the access points.
I'll appreciate your support
2 RESPUESTAS 2
Javier Acuña
Greetings you have run a spectrum analyzer to verify when closing the door how many decibels are reaching the equipment or how much is the signal level,
There are signal increase settings but you must be clear about how much signal is reaching the access point
Recuerda calificar este mensaje esto nos ayuda a mantener activa la comunidad de cisco.
Cheers for the assistance Javier
