01-25-2011 12:46 PM - edited 07-03-2021 07:43 PM
I have managed to get TACACS+ working for the WLC and WCS but having trouble with Radius for management authentication and authorization.
Anyone got and ideas or good documents on how to authenticate administrators using radius ACS 5.1 for WLC 5508 and WCS 6
I take it that I still need to define roles?
Many thanks.
Jay
Solved! Go to Solution.
01-30-2011 12:42 PM
You may try this with radius-ietf under shell-privelege
For read-write privileges for the user, set the Service-Type Attribute to Administrative.
For read-only privileges for the user, set the Service-Type Attribute to NAS-Prompt.
Jatin
Do rate helpful posts~
01-30-2011 12:42 PM
Jatin
