09-25-2023 01:14 PM
Is there a mounting plate that can connect both the base antenna and the access point in an exposed ceiling? Is there a typical exposed ceiling installation detail available? My understanding is that there would be a backbox anchored to the slab with conduit & threaded rod coming down to a backbox with mounting plate to connect the base antenna. How would the access point be mounted in an exposed ceiling?
09-26-2023 12:34 AM
- FYI : https://www.cisco.com/c/en/us/td/docs/wireless/antenna/installation/guide/ant2524v4c.html
M.
09-26-2023 02:17 AM
To mount both a base antenna and an access point in an exposed ceiling:
Secure a backbox to the ceiling structure using appropriate anchors.
Run conduit and threaded rods from the ceiling down to the backbox for cable routing.
Attach a suitable mounting plate to the backbox for the base antenna.
Mount the base antenna securely on the mounting plate.
Install the access point directly on the ceiling structure or suspend it using brackets.
Run network and power cables through the conduit to both devices.
Ensure proper cable management for a neat appearance.
Test and configure both devices for proper functionality.
Follow safety and aesthetic guidelines for a professional finish.
Document the installation details for future reference.
09-26-2023 02:20 AM
These AccelTex adapters maybe of help but first consult your provider.
https://www.acceltex.com/shop/universal-ap-and-antenna-articulating-mount/
https://www.acceltex.com/shop/antenna-mount-adapter-kit-for-3-inch-poles/
https://www.acceltex.com/shop/cisco-air-ant2513p4m-n-adapter-plate-for-ats-apantartmnt-univ1/
