sanjeevmahadani
Beginner
cisco air-ap1142n-a-k9 wireless access point wpa2 configuration issue
HI Folks,
I am very new on Cisco Wireless, just i have purchased new cisco air-ap1142n-a-k9 wireless access point, trying to configure the wpa2 configuration for security reason, but unable to configure in any security mode. So currently my AP is working no security / encryption mode.
Could any one can help and suggest me I'll appreciate if i'll get any documents so security issue can be resolved.
Sanjeev
19 REPLIES 19
HI Meldehne,
It's done...thanks......really really thanks
ok Great
Don't forget to rate correct answer and flag the thread as answered
I had same error but I followed this particular instructions and solved my problem at all, very very helpful, I do really appreciate it, thank you so much sir, you are the Man!
I had same problem, but I found the solution on this steps. Thank you Man!
I had same problem but I found the solution on this steps, thank you man!
Create
Recognize Your Peers
Content for Community-Ad
