04-23-2020 01:21 PM - edited 07-05-2021 11:58 AM
Hello guys,
Reading all docs and community here, I'm struggling to find an answer if WiSM2 could work with wirelessaaccess point AIR-AP4800-B-K9?
This document says WiSM2 will work: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/4800/quick/guide/ap4800getstart.html
(quote: The maximum number of access points varies for the Cisco WiSM2, depending on which controller software release is being used.)
However, the following documents says opposite (won't work): https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-4800-access-point/nb-09-air-4800-acces-ds-cte.html
Does anyone tried or know for sure if WiSM2 could work with AIR-AP4800-B-K9?
Cheers,
Solved! Go to Solution.
04-23-2020 03:06 PM - edited 04-24-2020 05:48 PM
4800 won't work with WiSM2.
4800 is first supported in 8.7.X.X and WiSM2 last firmware support is 8.5.X.X.
Options are to get the new 9800 or turn the 4800 into Mobility Express.
NOTE:
04-23-2020 02:10 PM
Hello
WISM2 and 4800 is not a possible combination.
WISM2 you can take it up to 8.5 code
4800 we introduce it in 8.7
NOTE:
