Cisco AIR SAP - WEB UI not working - firmware ap3g2-k9w7-tar.153-3.JK and upper
DmitryBond
Hi all,
Updated standalone access point 3702 (may be applied to all 1700, 2600, 2700, 3600, 3700 family) to new image ap3g2-k9w7-tar.153-3.JK and got WEB UI not working with "404 Not Found" error when Save Configuration pressed.
Update was performed using CLI:
User Access Verification
Username: Cisco
Password:
ap>enable
Password:
ap# format flash:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "flash:".Continue? [confirm]
flashfs[2]: 0 files, 1 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31739904
flashfs[2]: Bytes used: 1024
flashfs[2]: Bytes available: 31738880
flashfs[2]: flashfs fsck took 8 seconds.
Format of flash: complete
ap# archive download-sw /force-reload /overwrite tftp://10.1.0.2/ap3g2-k9w7-tar.153-3.JK.tar
examining image... Loading ap3g2-k9w7-tar.153-3.JK.tar from 10.1.0.2 (via BVI1): ! extracting info (280 bytes)
Image info: Version Suffix: k9w7-.153-3.JK Image Name: ap3g2-k9w7-mx.153-3.JK Version Directory: ap3g2-k9w7-mx.153-3.JK Ios Image Size: 10732032 Total Image Size: 13875712 Image Feature: WIRELESS LAN Image Family: AP3G2 Wireless Switch Management Version: 8.10.105.0 MwarVersion:080A6900.First AP Supported Version:07010100.
Image version check passed
Extracting files... ap3g2-k9w7-mx.153-3.JK/ (directory) 0 (bytes) extracting ap3g2-k9w7-mx.153-3.JK/ap3g2-k9w7-mx.153-3.JK (230195 bytes) extracting ap3g2-k9w7-mx.153-3.JK/ap3g2-k9w7-tx.153-3.JK (73 bytes) .....[cut extract process lines]..... extracting info.ver (280 bytes) [OK - 13916160 bytes] New software image installed in flash:/ap3g2-k9w7-mx.153-3.JK Configuring system to use new image...done. Requested system reload in progress... archive download: takes 127 seconds
After reboot AP successfully acquired IP address via DHCP, but doesn't start http server. Due to security reason in new firmware http server disabled by default and can't be enabled with default password for privileged (enable) mode. So this password needs to be changed and http server can be enabled.
Username: Cisco
Password:
ap>enable
Password:
ap#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
ap(config)#enable secret <mypass>
ap(config)#ip http server
ap(config)#end
ap#copy running-config startup-config
Destination filename [startup-config]?
Building configuration...
[OK]
ap#reload
Proceed with reload? [confirm]
After reboot WEB UI appears, but many functions not working properly. For example if Save Configuration pressed error "404 Not Found" appears making impossible to configure AP using WEB UI.
I tested also 15.3.3 JPI1 and 15.3.3 JPI4 firmware. Same issues.
Latest working version is 15.3.3 JJ1
Does anybody have the solution for this problem?
14 Replies 14
Cristian Matei
     Try upgrading to the latest version, there is one or two newer and see how it works. If still issues, try using different browsers. If still issues, raise a TAC case, as this year you still get bug fixes and development.
Cristian Matei.
DmitryBond
Hi All,
Tested newest firmware - 15.3.3 JPJ2.
Now it's better, but still not usable. In this version Cisco fixed most of WEB UI pages, but radio interface settings page is not working: controls are empty and Apply button has no effect.
NETWORK -> NETWORK INTERFACE -> Radio0-802.11N xxx -> SETTINGS
I have the same issue even with JPJ3.
Anyone solved this ?
Volker
No, open a TAC if you can.
It seems to work for some pages, but not all.
Workaround is to use the CLI.
Hi, I have exactly the same problem. Cisco is so good that they release software without testing! Pros!
The problem is basic and reproducible in 100%.
m.rana.ku
In the following video step by step process has been shown How to Configure Cisco AIRONET 3602i Autonomous/Standalone Access Point using GUI with WPAv2 Authentication Key.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://youtu.be/AwuWsGGofT4
Configuring Aironet Access Point with WPAv2 Authentication in GUI :
1. In Easy Setup
Under Network Configuration
Edit AP hostname, Static IP, Subnet mask and Default Gateway
Under In Radio Configuration
Create SSID name WLAN_New under Radio 2.4GHz and select Broadcast SSID in Beacon
2. Apply Encryption Modes to AES CCMP
3. Enable WPAv2 and apply WPA Pre-shared Key: to SSID
4. Enable Wireless Radio Interface (Radio0-802.11N2.4GHz/ Radio1-802.11N5GHz) UP
5. Save the configuration
6. Finally check the SSID Wi-Fi connection, Security Key, IP address and browsing through internet
jordan72
I think with version JPK its solved ( at least on my side )
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvu61065
Volker
It claims it is fixed, but with the JPK1 i'm still getting the 404 error when saving the config. So the issues are most def not solved with the web GUI.
How did you solved it?
General1
I am having an Arionet 3702E and experiencing the same issue.
"404 Not Found"
I tried the following firmware:
ap3g2-k9w7-tar.153-3.JPJ7.tar
Both having the same issue.
Going to try ap3g2-k9w7-tar.153-3.JJ1.tar next.
Tried a few more firmware and the web ui is still not working fully.
Here are the firmware I tried:
ap3g2-k9w7-tar.153-3.JH.tar
Ending up using the Cisco Network Assistant.
Did the CNA Worked?
Bertote
Hello.
Resurrecting the topic, is there any version that can be used on the SAP2602i that is configurable through the GUI without showing errors?
patoberli
I assume not, as they have been End of Life since several years.
Do you get the error on all pages or just a few? If just on some, then you could simply configure those via CLI and the rest web gui.
