cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
25
Respostas
Cisco Aironet 1600 function only in 54mb, how to configure for function in 150mb or 300mb?
25 RESPOSTAS 25
Rasika Naya
How to leaving the strongest signal?
The signal was very weak
How to expand the signal?
Thank a Lot
Post "show dot11 association <mac_address>" output for a wireless client that you see weak signal.
By increasing AP radio power, you can increase the coverage, but again end of the day client capability determine the effective cell size. If AP operate in high power, then client can hear AP, but AP cannot hear client back.
Rasika
*** Pls rate all useful responses ***
Hi Rasika,
Thank you for your attention , I could not find this post.
You can enhance the signal is weak? Do you have any configuration or command via terminal?
I'm waiting , thank you.
From your AP cli, can you see any output for "show dot11 association" command ?
Sorry about the delay, I had personal problems
What is "show dot11 association" command ?
I have two access point and both are with the weak signal and I do not
the option to configure the channels 11, 12, 13, 14
It is currently showing an error
Aironet Extensions Enabled
Carrier Set Americas
Configured Radio Channel 2452 MHz Channel 9
Transmitter Power error
Active Radio Channel 2452 MHz Channel 9
Channel Width 20 MHz
world mode Multi-Domain Operation: Disable
Recive Antenna: Diversity
Transmit Antenna: Diversity
Internal Antenna Configuration: Enable
Antenna Gain(dBi): 0
what I need to do to improve the signal strength?
follows an attachment
This is a CLI command you can run once you have telnet/ssh or console into AP.
In 2.4GHz, do not choose anything other than CH1, CH6 & CH 11. So in your channel selection, only select those 3 channels.
Move away from channel 9 & let it get one of 1,6,11
If you find our responses are useful , do not forget to rate our responses
Rasika
I put on channel 11
I run the command show dot11 association, he did not bring any results
The signal remains weaker than a simple conventional router
How to increases the power of the signal? [dBm]
signal [dBm]
Rasika
I Dont understand this procediment "show dot11 association <mac_address>"
What he does?
The signal is still weak, I need to improve the power to put the two aironets production.
I need help.I'm waiting , thanks a lot!
to improve the signal or access point must must be installed on the ceiling?
How does the spread of the access point 1602I signal?
Is there anything you can do to improve the signal strength?
Yes, these AP should be ceiling mounted for better use.
Refer below for coverage pattern for 1602I AP radios.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/apdeploy/Cisco_Aironet.html#28591
Rasika
mohanak
