Cisco Aironet 1815i Management HTTPS not working but SSH/ping is
pannkakan_1
Hi!
I have bit of a problem with my AP. I cant access the https GUI, only SSH/ping works. The AP is located in subnet A, and I am on subnet B. If I am on subnet A I can reach the web interface. From subnet B I can ping the AP and SSH to it but not access via HTTPS. I've checked my firewall settings and HTTPS/PING/SSH is allowed from Subnet B to A. Is there configuration setting I've missed or is it not possible?
Masato Ueoka
1. On subent B , telnet AP IP address 443 is possible?
2. Do you use proxy on your PC?
1. Telnet is not enabled, only SSH and HTTPS.
2. No Proxy
Telnet to AP port 443 means connection test for https.
Can you do it?
Ah I see. It doesnt work.
