Cisco Aironet 1815t Model without using the external powersupply
kvsa
is it possible to use the Cisco Aironet 1815t Model without using the external powersupply, e.g. powering it with a poe-switch ?
kind regards
Tobias
pieterh
don't looks like it, but it CAN supply PoE to another device like a camera or so.
you may look at the 1815w if you want PoE-powered model
Cisco Aironet 1815w
Powering options
●  802.3af/at Ethernet switch
●  Optional Cisco power injectors (AIR-PWRINJ5=, AIR-PWRINJ6=)
pieterh
Cisco Aironet 1815w
Powering options
thanks for research!
1815w was my previous choice, but the uplinkport to the switch is on the back! The AP will be placed on a desk (no wall mounting), so uplinkports on the back is a "no go".
The 1815T requires the supplied power supply. What I have done for teams that were testing is I also got the 1815W and purchased a single gang box and used heavy duty double sided tape to mount the 1815W on the table top. This way users would be able to connect devices to port 2/3.
-Scott
Here are some pics that I had. You can also mount these under the desk or find a smaller gang box.
-Scott
