Cisco Aironet 350 Plus OMNI antenna
teltac
Hi ,
i have one cisco Aironet 350 using Channel one connected to an outdoor OMNI antenna( 12 dbi) Mounted on a tower of 20 meter height and providing connectivity to multiple remote sites ,
i am planning to add another Cisco Aironet 350 in the same headoffice building that will be connected to an antother outdoor OMNI antenna ( 12 dbi) and will be used to connect another remote sites to headoffice for different purpose.
Taking into consideration , that the second Arionet 350 bridge will use a different Channel( Channel 6) , is it possible to mount the second antenna on the same tower ? if yes what should be the minimal distance between both antennas on the same tower ?
if a separate tower must be used for the second antenna , what must be the minimal distance between the two towers in order do not degrade or affect the performance ?
Thanks a lot for your reply
Ali
scottmac
Level 10
Level 10
You can mount both antennas on the same tower. As long as the antennas are (at least) several wavelengths apart (wavelength @ 2.4G is ~5 inches), they should be OK. The farther apart they are, the better.
If you can swing a meter or two between them you'll be fine.
Good Luck
Scott
