09-30-2020 12:53 PM - edited 07-05-2021 12:35 PM
Hello everyone,
i have 3802i as ME running with version 8.10.130.0 ,
i have two SSID one 2.4Ghz and one 5Ghz if i make Radio 1 automatic i can only see the 2.4Ghz SSID if i make it 5Ghz i can see the 5Ghz SSID
Radio 2 is enabled but no 5Ghz SSID is broadcasting.
can you please help me. thanks.
09-30-2020 07:14 PM
Turn off Flexible Radio Assignment (FRA) globally or the 5.0 Ghz micro radio gets triggered.
09-30-2020 09:07 PM - edited 09-30-2020 09:09 PM
thank you but still cant see the 5Ghz
(Cisco Controller) >show advanced fra
FRA State........................................ Disabled
FRA Operation State.............................. N/A
FRA Sensitivity.................................. low (100%)
FRA Interval..................................... 1 Hour(s)
Last Run....................................... 449 seconds ago
Last Run Time.................................. 0 seconds
Service Priority................................. Coverage
AP Name MAC Address Slot Current Band COF % Sensor % Suggested Mode
AP 00:7i:c8:i3:h5:50 0 2.4GHz None None None
COF : Coverage Overlap Factor
[] : COF when radio was in 2.4GHz Band
N/A : Non XOR Radio
09-30-2020 09:16 PM
(Cisco Controller) >show advanced client-steering
Client Steering Configuration Information
Macro to micro transition threshold............ -55 dBm
micro to Macro transition threshold............ -65 dBm
micro-Macro transition minimum client count.... 3
micro-Macro transition client balancing win.... 3
Probe suppression mode......................... disabled
Probe suppression validity window.............. 100 s
Probe suppression aggregate window............. 200 ms
Probe suppression transition aggressiveness.... 3
Probe suppression hysteresis................... -6 dB
WLAN Configuration Information
WLAN ID WLAN Profile Name / SSID 11k Neighbor Report 11v BSS Transition
1 TEST5ghz / TEST5ghz Enabled Enabled
2 TEST2.4ghz /TEST2.4ghz Enabled Enabled
09-30-2020 11:59 PM
Is the AP in an AP Group?
10-01-2020 03:49 AM
yes the default group, it could be FW issue ?
10-01-2020 08:31 AM
When you turn off FRA globally it doesn't automatically reset any APs which already had FRA applied.
You must use config advanced fra revert to reset radio assignments back to default.
10-01-2020 10:32 PM
issue has been resolved after downgrade to AIR-AP3800-K9-ME-8-5-161-0 then upgrade again to AIR-AP3800-K9-ME-8-10-130-0
08-13-2021 06:19 AM
Hi bikoo!
Thank you for your update! I had the exact same issue on a AP1562D running 8.10.151.0. Even a reset factory of the AP did not resolve the issue.
After downgrading ME to 8.5.161.0, 5GHz is now working fine.
Cheers
01-30-2023 05:51 PM - edited 01-30-2023 07:44 PM
I have a similar problem with Radio 2 on my 3802e AP.
Under Access Point Viiew screen, my AP indicates that Radio 1 (2.4) and Radio 2 (5) are both enabled but when I configure my AP there is only the ability to configure Radio 1 and there is no option to configure Radio 2.
Further, if I configure Radio 1 to act as a dedicated 5GHz WLAN then my Radio 1 disappears as well from the AP configuration screen.
can you please help me troubleshoot?
01-30-2023 07:41 PM - edited 01-30-2023 07:42 PM
Here are a couple of better screen shots:
