Cisco Aironet LR2 power injector - can't console into it?
Andy White
Level 3
Level 3
We have 2 Cisco Aironet Power Injector LR2's (AIR-PWRINJ-BLR2=) and I can't console to either using Cisco sky blue consoel cable.
I am using putty and my setting are:
Speed = 9600
Data Bits = 8
Stop Bits = 1
parity = none
Flow control = none
10 Replies 10
Leo Laohoo
I don't believe you can console into a power injector.  Why, if I should ask, are you doing this?
I was curious that's all. I have a 1301G to connect to it, is it used to configure that?
Oh no.
The power injector has only two options:  On or Off.
How do I configure the 1301 that connects to it via coaxial and why does the LR2 have a console port in the first place?
Under Network Management
The power injector does not require configuration or management.
Cisco Aironet 1300 Series Access Point/Bridge Power Injector
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a008022551d.html
Go to the website posted below.  Choose from either Configuration Examples & TechNotes or Configuration Guides.
http://www.cisco.com/en/US/customer/products/ps5861/tsd_products_support_configure.html
Hope this helps and please don't forget to rate our posts.  Thanks.
I spend the same, the AP 1310 is OK, but the power led led off injector LR2. Consoledoes not work
Faulty cable to the WAP.
Console Cable is ok, but led off power injector. AP LED is ok
Console Cable is ok
I'm not talking about the console cable.  The ethernet cable from the injector to the WAP could be faulty.
