Highlighted
Cisco AP 2602 joined with vWLC but there is no Wireless.
Hello all,
I have the following challange.
I deployed Cisco vWLC 7.5.102.0 and joined two AP Cisco 2602E which I successfully converted from AP to LAP. Both APs joined vWLC, enabled and show "operational status" REG. On vWLC I enabled broadcast SSID, checked radio 802.11a/b/g/n (enabled) and other things.
But I do not see any SSID (radio signal).
I tried different devices to find SSID (iPhone, Samsung Android phone, Laptop HP (InSSIDer application)).
It looks very strange for me because previousely when I deployed WLC-2500, once I join AP and enabled Radio - I was able to see SSID.
Will be glad to your ideas and ready to provide logs and screenshots.
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Few things...
  • Make sure your not using AP Groups or else you have to place those AP's in the appropriate AP Group
  • Make sure that the AP is in FlexConnect mode, since the vWLC only supports FlexConnect
  • If you have multiple country codes defined on the vWLC, that might also have an affect on what channel and power is available
If you still have issues, then post the following:
show ap summary
show wlan <wlan id>
-Scott
4 REPLIES 4
Highlighted
Hall of Fame Master
Few things...
show ap summary
show wlan <wlan id>
-Scott
Highlighted
Hi Scott Fella,
The problem was with FlexConnect. I changed mode and wireless appeared.
Thank you very much for your help!
Highlighted
Hi All , I did the same but no luck , changed the ap mode to FlexConnect , i have totally 18 aps out of which 17(2602I) are working fine only one (2602e)has this same problem (Cisco Controller) >show ap summary Number of APs.................................... 18 Global AP User Name.............................. Not Configured Global AP Dot1x User Name........................ Not Configured AP Name Slots AP Model Ethernet MAC Location Country IP Address Clients ------------------ ----- -------------------- ----------------- ---------------- ------- --------------- ------- AP4c00.82b9.8db2 2 AIR-CAP2602I-E-K9 4c:00:82:b9:8d:b2 default location NO 192.168.10.26 0 AP4c00.82b9.8d82 2 AIR-CAP2602I-E-K9 4c:00:82:b9:8d:82 default location NO 192.168.10.25 0 AP7c69.f604.9d45 2 AIR-CAP2602I-E-K9 7c:69:f6:04:9d:45 default location NO 192.168.10.16 1 AP0006.f689.be89 2 AIR-CAP2602I-E-K9 00:06:f6:89:be:89 default location NO 192.168.10.31 0 AP4c00.82b9.8dab 2 AIR-CAP2602I-E-K9 4c:00:82:b9:8d:ab default location NO 192.168.10.20 0 AP4c00.82b9.8d67 2 AIR-CAP2602I-E-K9 4c:00:82:b9:8d:67 default location NO 192.168.10.22 0 AP4c00.82b9.8d66 2 AIR-CAP2602I-E-K9 4c:00:82:b9:8d:66 default location NO 192.168.10.23 0 AP7c69.f626.5a6e 2 AIR-CAP2602I-E-K9 7c:69:f6:26:5a:6e default location NO 192.168.10.24 0 AP4c00.8270.eda5 2 AIR-CAP2602I-E-K9 4c:00:82:70:ed:a5 default location NO 192.168.10.18 0 AP4c4e.3563.90cf 2 AIR-CAP2602I-E-K9 4c:4e:35:63:90:cf default location NO 192.168.10.21 0 AP4c00.82b9.911c 2 AIR-CAP2602I-E-K9 4c:00:82:b9:91:1c default location NO 192.168.10.17 1 AP4c00.82b9.90e3 2 AIR-CAP2602I-E-K9 4c:00:82:b9:90:e3 default location NO 192.168.10.29 0 APb0fa.eb56.31bf 2 AIR-CAP2602I-E-K9 b0:fa:eb:56:31:bf default location NO 192.168.10.30 1 AP7cad.74db.8033 2 AIR-CAP2602I-E-K9 7c:ad:74:db:80:33 default location NO 192.168.10.34 0 --More-- or (q)uit AP4c00.82cb.d495 2 AIR-CAP2602I-E-K9 4c:00:82:cb:d4:95 default location NO 192.168.10.35 0 APb838.61b1.9a31 2 AIR-CAP2602E-E-K9 b8:38:61:b1:9a:31 default location NO 192.168.10.41 0 AP7c69.f626.5d09 2 AIR-CAP2602I-E-K9 7c:69:f6:26:5d:09 default location NO 192.168.10.32 1 AP7c69.f604.9adf 2 AIR-CAP2602I-E-K9 7c:69:f6:04:9a:df default location NO 192.168.10.33 3 APb838.61b1.9a31 2 AIR-CAP2602E-E-K9 b8:38:61:b1:9a:31 default location NO 192.168.10.41 0 ---- this is the ap having the problem (Cisco Controller) >show wlan 1 WLAN Identifier.................................. 1 Profile Name..................................... Wifi-Villa Network Name (SSID).............................. VillaWifi Status........................................... Enabled MAC Filtering.................................... Disabled Broadcast SSID................................... Enabled AAA Policy Override.............................. Disabled Network Admission Control Client Profiling Status Radius Profiling ............................ Disabled DHCP ....................................... Disabled HTTP ....................................... Disabled Local Profiling ............................. Disabled DHCP ....................................... Disabled HTTP ....................................... Disabled Radius-NAC State............................... Disabled SNMP-NAC State................................. Disabled Quarantine VLAN................................ 0 Maximum number of Associated Clients............. 0 Maximum number of Clients per AP Radio........... 200 --More-- or (q)uit Number of Active Clients......................... 6 Exclusionlist Timeout............................ 60 seconds Session Timeout.................................. 1800 seconds User Idle Timeout................................ Disabled Sleep Client..................................... disable Sleep Client Timeout............................. 12 hours User Idle Threshold.............................. 0 Bytes NAS-identifier................................... CISCO-WLC CHD per WLAN..................................... Enabled Webauth DHCP exclusion........................... Disabled Interface........................................ wifi-users Multicast Interface.............................. Not Configured WLAN IPv4 ACL.................................... unconfigured WLAN IPv6 ACL.................................... unconfigured WLAN Layer2 ACL.................................. unconfigured mDNS Status...................................... Enabled mDNS Profile Name................................ default-mdns-profile DHCP Server...................................... Default DHCP Address Assignment Required................. Disabled Static IP client tunneling....................... Disabled Quality of Service............................... Silver Per-SSID Rate Limits............................. Upstream Downstream Average Data Rate................................ 0 0 --More-- or (q)uit Average Realtime Data Rate....................... 0 0 Burst Data Rate.................................. 0 0 Burst Realtime Data Rate......................... 0 0 Per-Client Rate Limits........................... Upstream Downstream Average Data Rate................................ 0 0 Average Realtime Data Rate....................... 0 0 Burst Data Rate.................................. 0 0 Burst Realtime Data Rate......................... 0 0 Scan Defer Priority.............................. 4,5,6 Scan Defer Time.................................. 100 milliseconds WMM.............................................. Allowed WMM UAPSD Compliant Client Support............... Disabled Media Stream Multicast-direct.................... Disabled CCX - AironetIe Support.......................... Enabled CCX - Gratuitous ProbeResponse (GPR)............. Disabled CCX - Diagnostics Channel Capability............. Disabled Dot11-Phone Mode (7920).......................... Disabled Wired Protocol................................... None Passive Client Feature........................... Disabled Peer-to-Peer Blocking Action..................... Disabled Radio Policy..................................... All DTIM period for 802.11a radio.................... 1 DTIM period for 802.11b radio.................... 1 --More-- or (q)uit Radius Servers Authentication................................ Global Servers Accounting.................................... Global Servers Interim Update............................. Disabled Framed IPv6 Acct AVP ...................... Prefix Dynamic Interface............................. Disabled Dynamic Interface Priority.................... wlan Local EAP Authentication......................... Disabled Security 802.11 Authentication:........................ Open System FT Support.................................... Disabled Static WEP Keys............................... Disabled 802.1X........................................ Disabled Wi-Fi Protected Access (WPA/WPA2)............. Enabled WPA (SSN IE)............................... Enabled TKIP Cipher............................. Enabled AES Cipher.............................. Disabled WPA2 (RSN IE).............................. Disabled Auth Key Management 802.1x.................................. Disabled PSK..................................... Enabled CCKM.................................... Disabled --More-- or (q)uit FT-1X(802.11r).......................... Disabled FT-PSK(802.11r)......................... Disabled PMF-1X(802.11w)......................... Disabled PMF-PSK(802.11w)........................ Disabled FT Reassociation Timeout................... 20 FT Over-The-DS mode........................ Enabled GTK Randomization.......................... Disabled SKC Cache Support.......................... Disabled CCKM TSF Tolerance......................... 1000 WAPI.......................................... Disabled Wi-Fi Direct policy configured................ Disabled EAP-Passthrough............................... Disabled CKIP ......................................... Disabled Web Based Authentication...................... Disabled Web-Passthrough............................... Disabled Conditional Web Redirect...................... Disabled Splash-Page Web Redirect...................... Disabled Auto Anchor................................... Disabled FlexConnect Local Switching................... Disabled flexconnect Central Dhcp Flag................. Disabled flexconnect nat-pat Flag...................... Disabled flexconnect Dns Override Flag................. Disabled flexconnect PPPoE pass-through................ Disabled --More-- or (q)uit flexconnect local-switching IP-source-guar.... Disabled FlexConnect Vlan based Central Switching ..... Disabled FlexConnect Local Authentication.............. Disabled FlexConnect Learn IP Address.................. Enabled Client MFP.................................... Optional but inactive (WPA2 not configured) PMF........................................... Disabled PMF Association Comeback Time................. 1 PMF SA Query RetryTimeout..................... 200 Tkip MIC Countermeasure Hold-down Timer....... 60 AVC Visibilty.................................... Disabled AVC Profile Name................................. None Flow Monitor Name................................ None Split Tunnel (Printers).......................... Disabled Call Snooping.................................... Disabled Roamed Call Re-Anchor Policy..................... Disabled SIP CAC Fail Send-486-Busy Policy................ Enabled SIP CAC Fail Send Dis-Association Policy......... Disabled KTS based CAC Policy............................. Disabled Assisted Roaming Prediction Optimization......... Disabled 802.11k Neighbor List............................ Disabled 802.11k Neighbor List Dual Band.................. Disabled Band Select...................................... Disabled Load Balancing................................... Disabled --More-- or (q)uit Multicast Buffer................................. Disabled Mobility Anchor List WLAN ID IP Address Status ------- --------------- ------ 802.11u........................................ Disabled MSAP Services.................................. Disabled Local Policy ---------------- Priority Policy Name -------- --------------- Regards Saran
Highlighted
Hi Scott,
Thanks for your help, it works for me ...
Content for Community-Ad
