12-05-2019 07:40 PM - edited 07-05-2021 11:23 AM
My Cisco AP 2802i Not Joining with WLC-2500. it is the only ap i want to connect to WLC.
[*12/05/2019 17:30:38.3775] SYS-COND: AP is in fair condition
[*12/05/2019 17:30:38.8789] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*12/05/2019 17:30:38.8827] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*12/05/2019 17:30:38.9025] AP IPv4 Address updated from 0.0.0.0 to 192.168.100.4
[*12/05/2019 17:30:39.6212] dtls_init: Use SUDI certificate
[*12/05/2019 17:30:39.6215]
[*12/05/2019 17:30:39.6215] CAPWAP State: Init
[*12/05/2019 17:30:39.6220]
[*12/05/2019 17:30:39.6220] Config not found, PNP is required, Starting PNP
[*12/05/2019 17:30:43.2854] PNP:Server not reachable, Start CAPWAP Discovery
[*12/05/2019 17:30:43.2857]
[*12/05/2019 17:30:43.2857] CAPWAP State: Discovery
[*12/05/2019 17:30:43.2882] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/05/2019 17:30:43.2882] CAPWAP State: Discovery
[*12/05/2019 17:30:43.2897] Discovery Response from 192.168.100.10
[*12/06/2019 11:12:28.0000] can't find the Ip from discoveryRequest array
[*12/06/2019 11:12:28.0001]
[*12/06/2019 11:12:28.0001] CAPWAP State: DTLS Setup
[*12/06/2019 11:12:28.6747]
[*12/06/2019 11:12:28.6747] CAPWAP State: Join
[*12/06/2019 11:12:28.6772] Sending Join request to 192.168.100.10 through port 5272
[*12/06/2019 11:12:28.6793] Join Response from 192.168.100.10
[*12/06/2019 11:12:28.7696] HW CAPWAP tunnel is ADDED
[*12/06/2019 11:12:28.7871]
[*12/06/2019 11:12:28.7871] CAPWAP State: Image Data
[*12/06/2019 11:12:28.8237] do NO_UPGRADE, part1 is active part
[*12/06/2019 11:12:28.8289]
[*12/06/2019 11:12:28.8289] CAPWAP State: Configure
[*12/06/2019 11:12:28.8313] DOT11_CFG[0] Radio Mode is changed from Local to Local
[*12/06/2019 11:12:28.8319] DOT11_CFG[1] Radio Mode is changed from Local to Local
[*12/06/2019 11:12:31.6105] Re-Tx Count=1, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/06/2019 11:12:34.4613] Re-Tx Count=2, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/06/2019 11:12:37.3122] Re-Tx Count=3, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/06/2019 11:12:40.1631] Re-Tx Count=4, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/06/2019 11:12:43.0139] Re-Tx Count=5, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/06/2019 11:12:45.8648] Re-Tx Count=6, Max Re-Tx Value=5, SendSeqNum=1, NumofPendingMsgs=1
[*12/06/2019 11:12:45.8648] Max retransmission count exceeded, going back to DISCOVER mode.
[*12/06/2019 11:12:45.8649] GOING BACK TO DISCOVER MODE
[*12/06/2019 11:12:45.8655]
[*12/06/2019 11:12:45.8655] CAPWAP State: DTLS Teardown
[*12/06/2019 11:12:51.6794]
[*12/06/2019 11:12:51.6794] CAPWAP State: Discovery
[*12/06/2019 11:12:51.6851] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*12/06/2019 11:12:51.6858] Discovery Response from 192.168.100.10
[*12/06/2019 11:13:01.0000] can't find the Ip from discoveryRequest array
12-05-2019 07:56 PM
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. WLC: sh ap join stats detailed <AP name>; and
4. AP: sh version
12-09-2019 06:03 PM
Hi bor , thank you for your advice. I solve the problem alr. I use the wrong contry code . the ap 2802i-D is made in india.
12-07-2019 02:15 AM
