02-09-2012 01:05 PM - edited 07-03-2021 09:33 PM
Curious as the range of the AIR-LAP1142N-A-K9 access point ?
Also has anyone mounted these above the ceiling tiles in an office space..
To keep them out of view I had them mounted above the ceiling tiles and dont seem to be getting the best performance out of them.
I have offices that are literally 30 - 50 ft away that has a hard time getting any decent signal out of them
Also is there a way to adjust their power output via the control panel of cli ?
Cheers
Dave
02-09-2012 01:09 PM
Anytime you mount ap's above the ceiling tile, you might loose some coverage or a lot. Just depends on if its resting on the tile, mounted up in the plenum ceiling or if there is obstruction around where the ap is placed. If you ap's are showing power level of 1, then you are at the highest tx power and you will not be able to do anything about that. Other here will also suggest you mount them below or you will just have to add additional to cover the areas you need.
02-09-2012 01:14 PM
Where do I find the power level of 1 value ? In the wireless controller interface or do I have to login to the AP ?
02-09-2012 01:20 PM
In the WLC, click on the wireless tab on top and then on the left, you can select 802.11an or 802.11bgn and look on the right side.
02-09-2012 01:25 PM
Got it thanks....looks like they are all set to power level 0, I guess I can change that to 1 ? Is that a global setting or do I have to configure each AP ?
02-09-2012 01:29 PM
Power level 0? There is something wrong. Try to set it and see if it takes. What code are you running on the wlc. Maybe try to reboot the wlc.
Scott Fella
Sent from my iPhone
02-09-2012 02:22 PM
Looks like I am running a pretty old code on this.. 6.0.196.0 so I'll have to update it to the latest and greatest.
Do I need to worry about any licensing issues if I upgrade the code ?
Also with regards to the power settings..Looks like if I go with custom settings I have a choice of 1 - 7. Would 7 be the max power setting or 1 ?
Cheers
Dave
02-09-2012 02:41 PM
1 would be the highest and 7 the lowest. Go ahead and upgrade... The latest 7.0.x is good.
Scott Fella
Sent from my iPhone
02-09-2012 02:46 PM
What model WLC? There is no licensing for code upgrade you have to worry about.
Scott Fella
Sent from my iPhone
02-10-2012 02:43 AM
the correct "dBm" level You can see:
connect to CLI
(Cisco Controller) >show ap config 802.11b AP-Name
##### in the 4 sections are the values and the adjustment #######
Tx Power
Num Of Supported Power Levels ............. 7
Tx Power Level 1 .......................... 17 dBm
Tx Power Level 2 .......................... 14 dBm
Tx Power Level 3 .......................... 11 dBm
Tx Power Level 4 .......................... 8 dBm
Tx Power Level 5 .......................... 5 dBm
Tx Power Level 6 .......................... 2 dBm
Tx Power Level 7 .......................... -1 dBm
Tx Power Configuration .................... AUTOMATIC
Current Tx Power Level .................... 1
output from AP are 17 dBm = 50mw
miro
