Cisco CAP1602i-E-K9 registration issue with WLC 5508
Asad Raza
Beginner
Beginner
Hello everyone,
I am trying to register a 1602i with a WLC 5508, but I am unable to do so. Here is the information I currently have:
WLC:
Model: 5508
Boot version: 12.4.25.1
IOS version:  12.4(25e)JA1$
Mini IOS version: 7.4.1.37
Access point:
Model: AIR-CAP1602I-E-K9
IOS version: 15.2(4)JA1
LWAPP image: 7.5.1.73
The WLC is already controlling 1242 APs without issues. The 1602Is however, are unable to register with this WLC. There is no Option 60 or 43 defined on the DHCP server, however, both the WLC and the APs are on the same subnet.
I am receiving the following messages on the console (where x denotes customer information that has been "Xed" out due to privacy reasons):
Translating "CISCO-CAPWAP-CONTROLLER.XXXXXX.COM"...domain server (x.x.x.x)
*Mar  1 00:02:55.070: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:02:58.070: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.XXXXXX.COM
*Mar  1 00:03:08.070: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'XXX-XXX-XX'running version 7.2.110.0 is rejected.
*Mar  1 00:03:08.070: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:03:08.070: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:03:08.070: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:03:08.070: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from x.x.x.x
*Mar  1 00:03:53.569: %CAPWAP-3-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar  1 00:03:56.577: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 2 combination.
*Mar  1 00:03:56.645: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address x.x.x.x, mask x.x.x.x, hostname APxxxx.xxxx.xxxx
Translating "CISCO-CAPWAP-CONTROLLER.OAMC.COM"...domain server (x.x.x.x)
*Mar  1 00:04:03.569: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
I tried entering a static IP address, static controller IP address, static default gateway address, but I receive the following messages and the AP reboots:
*Mar  1 00:14:49.463: %CAPWAP-3-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP.
I would appreciate any assistance with this problem!
Asad Raza
Rasika Nayanajith
VIP Mentor VIP Mentor
VIP Mentor
Looks like your WLC is running on 7.2.110.0, Please upgrade your WLC to  7.4.121.0 code & see. It should work.
Here is reference compatibility matrix (see table 2)
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rasika
**** Pls rate all useful responses ***
Leo Laohoo
Hall of Fame Community Legend Hall of Fame Community Legend
Post the following output:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version; and
4.  AP:  sh ip interface brief
Rasika Nayanajith
VIP Mentor
Rasika
Hi Manannalage,
You're right, that was the issue. We've notified the client that they need to upgrade the lwapp image. Thanks for your help!
Asad
Recognize Your Peers
