Cisco CMX 10.3 and Cisco Prime Infrastructure 3.1
cammaher
I am new to using Cisco CMX and it's capabilities, so apologies if this has been answered previously, but I couldn't find it anywhere.
Is it possible to get Cisco CMX to provide wireless coverage heatmaps (similar to what Cisco Prime Infrastructure can do)?
Also, is it possible to use Cisco CMX without having Cisco Prime Infrastructure. Can you just create the maps and add the WAPs direct into CMX without using Cisco Prime?
Thanks in advance.
 Long time don't install and manage MSE but from version 10 and newer you can view the map on the CMX web page directly. However, as far as I remember, you need to export maps from Prime and import to CMX.
-If I helped you somehow, please, rate it as useful.-
