07-22-2020 01:26 PM - edited 07-05-2021 12:18 PM
I do not see Meraki wireless here:
https://www.cisco.com/c/en/us/products/software/dna-subscription-wireless/index.html
it says:
The wireless infrastructure becomes the strongest first line of defense, with Encrypted Traffic Analytics (ETA) and Software-Defined Access (SD-Access)
I know Meraki does not support ETA, does Meraki support Software-Defined Access ?
I am deciding between Meraki and on-premises WLC.
Your response will be appreciated.
Edouard.
Solved! Go to Solution.
07-22-2020 07:08 PM
I haven't seen people using Meraki WiFi with DNA. Some people use it with ISE, but not many.
The solution is so comprehensive people tend to use it on its own.
07-22-2020 07:08 PM
