12-15-2012 02:02 PM - edited 07-03-2021 11:13 PM
Following the recent iOS 6 update, our company iPads with this version installed cannot be provisioned via our Cisco ISE Device provisioning portal.
iPads running version 5 can be successfully provisioned, however version 6 iPads cannot.
I do have a TAC raised regarding this issue, however can I ask please if anyone has knowledge of this happening to them and any possible fixes.
Jon
12-18-2012 05:25 AM
I think this is the same Problem i have with the WebAuth when it´s provided by WLC.
You try to connect with the guest network that works. Then Safari opens and try to access the Web Auth Website.
Then Safari says that the Website is untrustworthy or something like that right ?
I think the reason is why you use a Self Signed Certificat.
So if the Browser can trust your ISE you need an Offical Certificat signed by a CA
12-18-2012 11:06 AM
Many thanks for getting back to me and have come across the same issue as you are experiencing until a workaround was established using central web authentication directly from ISE.
The issue I have is that corporate iPads with iOS6 installed will not be forwarded to the ISE web portal after installing required certificates issued by the CA.
The process worked fine for iPads with version 5 installed and also those upgraded to 6 from version 5 but not for iOS6 iPads out of the box??
12-19-2012 12:16 AM
I have exectally the same problem with the WebAuth when its provided by WLC
I think you have to generate an offical Cert signed by Chained CA.
I opened a Threat for my WLC Problem
01-18-2013 02:03 AM
Hi Jon
I have the same problem, did you find a solution?
Tim
