04-18-2021 10:05 AM - edited 07-05-2021 01:10 PM
HI GUYS,
i have following design and need to ask below question:
-Deployment of access point inside a rugged environment e.g. warehouse, we select the access point based on site condition.
W3702-2E-x-K9 | Access point with four antenna connectors: 2 on the top and 2 on the bottom. |
-My Question is ;
Do we required to use RF adaptors and cable in this type implementation to connect omni direction antenna PID AIR-ANT2547VG-N to access point;
This is a typical indoor implementation, so i think we don't required to purchase RF adaptors/cables, we can only connect the antenna directly with access point ?
reference: Cisco IW3702 Access Point Getting Started Guide - Cisco
adaptors detail:
2 x N(f) to N(f) RF adapters. Cisco PID AIR-ACC370-NF-NF.
2 x DC pass, N(m)-N(f) lightning arrestors. Cisco PID CGR-LA-NM-NF.
Outdoor Cables
Select from:
2 x N(m)-R/A to N(m)-STR, LMR-400-DB , 5’ RF cable, Cisco PID: CAB-L400-5-N-N
2x N(m)-STR to N(m)-STR, LMR-400-DB , 5’ RF cable, Cisco PID: CAB-L400-5-N-NS
2x N(m)-R/A to N(m)-STR, LMR-400-DB , 10’ RF cable, Cisco PID: AIR-CAB010LL-N
2 x N(m)-R/A to N(m)-STR, LMR-400-DB, 20’ RF cable, Cisco PID: CAB-L400-20-N-N
2 x N(m)-R/A to N(m)-STR, LMR-600-DB, 30’ RF cable, Cisco PID: CAB-L600-30-N-N
2 x N(m)-STR to N(m)-STR, LMR-400-DB, 25’ RF cable with petrochemical and oils resistance, Cisco PID AIR-CAB025HZ-N
04-18-2021 10:40 AM
04-18-2021 10:51 AM
thanks scott for your reply,
secondly the cable for PoE IN port is a 8-pin M12 X and the cable will purchase separately?
cable Information:
AB-ETHRJ45-M12-10= M12 to RJ-45 Ethernet cable, 8 pins, X-Code, 10 ft
04-18-2021 11:47 AM
